9.0.2.36198
Posted by:EPHERE
Data created:2 June 2025
New: Clump manipulators
New: Using colors to differentiate clumps and clump hair selections
New: Moved Edit Guides mode selection to its own rollout
New: Reordered Edit Guides rollouts for brushes to appear in a more firendly configuration
New: Edit Guides button icons
New: Moved color box from paint brush to channel drop-down, alongside channel value
New: Using color value when modifying color channels and spinner when modifying greyscale ones
New: Added icons to Edit Guides buttons
New: Improved the Edit Guides "current channel" combo box with tooltips, colors, and less verbosity
New: Delete channel option removed compound channels
New: Clump index channel name can be specified
New: Channel selector button and dialog replaced with a better drop-down and a "paint channel" button
New: Generated clump centers are calculated to be more correctly (at the center of each clump)
Fixed: "Grab/Pull" option not working with the paint brush
Fixed: Correct edit mode not specified in the Edit Guides mode selector after scene load
Fixed: Display selection overlay in Edit Guides by default
