9.1.3.38025
Posted by:EPHERE
Data created:20 February
New: Isolate Hair mode will be automatically stopped if you enable Show End Result. This makes SER and Isolate fully incompatible with one another, enabling one disables the other.
Fixed: Potential crash in Mesh from Strands
Fixed: Assertion when baking grounded strands which didn't have surface dependencies
Fixed: Core error leading to broken clumps when using strand groups
Fixed: Tested and fixed a bug in groom evaluator for disabled nodes (corruption of parameter data)
Fixed: Sporadic crash fix in control points draw code
Fixed: An issue calculating diff in Edit Guides between hair where a root has also been modified and rotated
Fixed: Control points section empty when adding a new Edit Guides modifier while already in another Edit Guides modifier
