9.1.5.38342
Posted by:EPHERE
Data created:20 April
New: 3dsmax 2027 support
New: Graft surface normals are always displayed (feels more natural to see them)
New: Dragging starting from the mesh, if there's a strand occluded by the mesh, will create a new strand instead of editing the occluded strand
New: Draw strands can be used to alter a segment/interval inside the strand
Fixed: Animation cache UI incorrect dimming
Fixed: Paint channel option adds EG mod directly below currently modifier, not below the last HFG modifier
Fixed: Clump hair selection is not visible when there are no clumps
Fixed: Control Points center incorrect when using multi-CP mode
Fixed: A sporadic crash when re-loading groom graphs in Groomer
Fixed: An assertion (without crash) when changing to a graft groom directory which doesn't have cache yet
Fixed: Demoted warning to verbose message when an Edit Strands operator is re-applied after increasing incoming strand number
Fixed: An error saving data to clumper parameters
Fixed: Surface-tracked shape change composition to preserve the higher point count when composing two non-empty changes with differing vector counts, matching the behavior already used in the specific-tracked path.
Fixed: A crash in graft manager if cache file is corrupted (or has invalid format)
Fixed: Error when loading some groom files
