9.1.6.38646
Posted by:EPHERE
Data created:10 June
New: Optimized strand shape (both specific and surface) diff calculation and delta application by using direct vertex access
New: IsMirrorHalf graft surface implicit property
New: Graft groom list and shared groom dialog to use recursive search and stored thumbnail paths
Fixed: Surface Comb sinks are too thin
Fixed: A rare case where loading a groom file could leave guides in a corrupt state
Fixed: Push Away from Surface prefers distribution character mesh when nothing else is provided
Fixed: Strands snap and stretch after Rotate + Comb/CP modifications
Fixed: Hair from Guides operator not propagating the character mesh from input guides to the generated hair
Fixed: Mesh flip normals flag not copied during cloning
Fixed: Groomer RescaleValue failing to store scaled GuidesDelta values by writing back with the parameter's concrete type instead of the IObjectSpaceScalable interface type.
Fixed: GraftManager cache loading to gracefully discard and recreate incompatible or corrupt cache files instead of throwing, and added a test.
Fixed: An issue with Animation Cache + HFG. The animation doesn't work when we use standard interpolation.
Fixed: The channel display broke while painting.
