| Data created: | 27 August | |
New: - Isolate Selected in Edit Guides is now a reversible visibility layer with a hotkey, and the previous permanent behavior is available as Hide Unselected (#7253) - Added a Match Strand Groups option to Adopt External Guides, so each hair strand follows only the control guides of its own strand group (#6862) - Added a Concatenate Strand Groups option to Merge, which renumbers each merged object's strand groups so they cannot overlap (#7269) - Even clump distribution can now be used together with a distribution map - Guides created with the Create brush and strands drawn with the Draw Strand tool now inherit the strand group and other data of the closest guide, with per-data options (#7138, #7139, #7142) - The last selected Edit Guides brush is remembered instead of falling back to Comb (#5053) - Parameter rollouts now enable and disable their controls based on other parameter values (#7242, #7245, #7246) - Groom files are smaller through binary storage of mesh face indices (#7209) - The Ornatrix V-Ray plugin is now deployed into V-Ray Standalone (#3973) Fixed: - Crash when an operator enables guide dependencies on hair which has none (#7109) - Baked hair not being loaded from its source file after a scene is loaded (#7110) - Strand Multiplier assert in Reinterpolate when its change cache is enabled (#7249) - Remembered root positions not disabling the distribution controls (#7250) - Hair from Guides regenerating roots on every evaluation when a distribution map is assigned (#7068) - Deleting a strand created by the same guides delta in Edit Guides (#7059) - Hidden guides reappearing on the next evaluation (#7255) - Adopt External Guides ignoring the control guides when the three nearest ones are collinear (#7108) - Per-clump and pattern knot parameters not taking effect until the groom was reloaded (#7147) - Clumping assert when Use UV Space names a mapping channel the hair does not have (#7244) - Merged ungrounded strands and merge target strands being moved to the first distribution mesh face (#7221, #7224) - Merged strands grounded to a different distribution mesh being re-planted (#7223) - Dynamic grounding failing when no source surface is set (#7226, #6819) - Mesh from Strands crash with Conform to Surface when the distribution mesh is carried only by the hair (#7213) - Cap Ends breaking the Mesh from Strands output (#7322) - Meshes exported to Alembic having inverted face winding (#7327) - Groom script parameter values being lost on scene save and reload (#7219) - Groom scan recursing until stack overflow when a groom references a graft surface missing from its directory (#7325) - Create Groom assert when the graft grooms cache file cannot be removed (#7241) Marsel Khadiyev (Software Developer, EPHERE Inc.) |
