| Data created: | 21 June 2015 | |
+ Added: Quick hair command VRayOrnatrixMode not added when VRay RT renderer is used + Added: Quick hair option checks objects for instancing ability before trying to add hair to them. Error message is displayed instead of crashing Max. + Added: Installer sets up Ornatrix toolbar * Fixed: Hair clusters are generated different on each run * Fixed: Frizz diagram crash * Fixed: Floating certain diagrams crashes Max * Fixed: Root planting can produce incorrect roots which destabilize all other guides * Fixed: When UVs are not inherited or generated per-strand in mesh from guides proxy mode the resulting mesh has valid UV coordinates * Fixed: Skip static PhysX actors for attaching in DynamicsModifier. Prevents a MassFX error in some cases. * Fixed: Skip tiny (less than 1% from max length) guides simulation in Ox Dynamics modifier and fixed zero length capsule creation fail * Fixed: Alembic export crash with multiple exported objects Marsel Khadiyev (Software Developer, EPHERE Inc.) |
