| Data created: | 5 July 2015 | |
+ Added: Ability to specify install location using new installer (Setup allows selecting the directory for the .dlo file, all the other files are installed into their appropriate locations within the Max root) + Detail modifier speed improvement + Added: OxCreateGroom and OxGenerateGroom MXS functions, part of a larger new groom presets functionality * Fixed: Detail modifier not smoothing interpolated strands properly * Fixed: VRay distance texture does not work with distribution maps * Fixed: Last point of hair clustering diagram is not editable * Fixed: Sporadic error deleting individual guides in Edit Guides modifier * Fixed: Tiny/ultra-short guides causing dynamics simulation problems * Fixed: Do not apply DynamicModifier from PhysX callbacks if modifier was switched off * Fixed: Set whole number in degrees for default swing limit in DynamicsModifier * Fixed: Reset presets diagrams too in DynamicsModifier * Fixed: Display wisps size in world units in DynamicsModifier * Fixed: Keep default mass and wisp radius in presets in DynamicsModifier Marsel Khadiyev (Software Developer, EPHERE Inc.) |
