+ New: License server IP file can be specified using an environment variable
* Fixed: Change MR shader install directory on Max 2017
* Fixed: Hair clustering modifier low threshold value causes hair to flicker on deforming mesh
* Fixed: Remove "reorient hair node" option from Ground Strands modifier (it did nothing)
* Fixed: Assertion during grounding about direction vector not being unit size
