| Data created: | 22 October 2017 | |
New: Added multi-threading to Surface Comb New: Switched propagation modifier to use new Qt curve diagrams in Max 2017 and above New: Updated OX Edit Guides graphs to new graphs with presets New: Surface Comb bending now has value range allowing to bend backwards and more forward New: Planted Guides should inherit the Strand Group of the selected guide if Strand Groups are present Fixed: Ornatrix toolbar not showing up in all workspaces in 3dsMax 2018 Fixed: Max crashes when importing splines into EG Fixed: Strand group info embedded in hair lost when changing distribution type Fixed: No hair is generated when using 1 incoming guide and 1 guide interpolation Fixed: Hair with polar interpolation randomly changes rotation on deforming meshes if it is parallel to the surface normal Fixed: Sporadic problems with Is Inside Mesh test in Generate Guide Data modifier Fixed: Hair artifacts when using Interpolation Weight in combination with Segment Interpolation Marsel Khadiyev (Software Developer, EPHERE Inc.) |
