| Data created: | 7 March 2018 | |
New: Support for object-space map vectors for direction in Surface Comb modifier New: Added Frizz, Curl, and Gravity node texture map channel support New: Ox Hair texture can read one or more hair data channels as color New: Detail modifier supports strand rotations New: Detail modifier supports strand widths New: Fast Raytracer will not render objects which have VRayOrnatrixMod in them (avoids double rendering with VRay) Fixed: Hairs rotated when exiting sub-object mode after moving said hairs roots Fixed: Crash when enabling auto-partings in Hair from Guides modifier and dragging the threshold spinner Fixed: Import single spline in Edit Guides modifier not working on Max 2018+ Fixed: ChangeWidth modifier does not work with propagated strands Fixed: Issues applying Hair from Guides modifier on top of propagated guides Fixed: Crash when applying Hair from Guides modifier to guides with varying point count Marsel Khadiyev (Software Developer, EPHERE Inc.) |
