| Data created: | 11 September 2018 | |
New: Hair from Guides isolation sub-object mode (WIP) New: Removed build and deployment for Max 2013 and earlier Fixed: Bottom row of HFG distribution buttons can be selected when Remember Roots option is on Fixed: Some modifiers don't return correct validity interval and are not re-evaluated when animated Fixed: Guide clumping method does not work correctly Fixed: Curling operator crashes with some configurations Fixed: Max crashes when using the "Assign Channel" button in Ox Clump modifier Fixed: Auto-push away from mesh not working in Edit Guides Fixed: Incorrect texture coordinates in optimized mesh hair display Fixed: Hair disappears from viewport while grooming Fixed: Hair is not displayed in the viewport when using Performance display method Fixed: Max crashes when changing the Viewport Hair Rendering Method to Mesh Fixed: Clump Guides method don't match the Clump Editing Guides Fixed: Unable to delete planted guides in Edit Guides in some scenes Fixed: Broken Strand Groups when deleting hair strands Fixed: Fixed: MoovPhysics CosseratElaston hair model very slow Marsel Khadiyev (Software Developer, EPHERE Inc.) |
