| Data created: | 27 September 2018 | |
New: Arnold render support New: Added an option to Ground Strands modifier to generate texture coordinates from surface New: Parameter groups and separators in MoovPhysicsModifier UI New: Added an option to switch between global and local strand segment orientations Fixed: Hair clustering modifier produces randomly flying away hairs Fixed: Strands in default group should not have red color Fixed: Plant Guide tool: Planted guides don't inherit the strand group of the selected guide Fixed: Select By Group option is not working Fixed: Distorned imported splines in Edit Guides Fixed: Ox Clump curves doesn't work in 3dsmax 2016 Fixed: Curler results and speed improvements Fixed: Hair changes shape when modifying global segment orientation parameter and changing curl value Fixed: Alembic exporter and importer not setting UV coordinates correctly Fixed: Adopt External Guides modifier doesn't respect animation of control hair Fixed: Hair from Guides modifier doesn't respect input guides animation Fixed: Curling modifier can cause a crash in some scenes Fixed: Optimize mesh view bug in 3ds max 2016 Marsel Khadiyev (Software Developer, EPHERE Inc.) |
