| Data created: | 12 October 2018 | |
New: Alembic can export velocity data with interval center and length parameters New: Added an option to Clumping wth guides to only specify clump roots (and not the clump stem shapes) New: Added entries to Ox global menu to create modifiers and objects New: Updated Ox toolbar to contain new modifiers Fixed: Oscillator modifier crashes when clicking channel select buttons Fixed: Invert selection doesn't work Fixed: Oscillator makes some guides jump when using Wind force Fixed: Oscillator modifier stiffness map and channel aren't working Fixed: Hair and guide roots aren't generated if UV coordinates are too small on a mesh Fixed: Oscillator modifier doesn't respect animated forces Fixed: Changing input per-strand data causes Hair from Guides to re-generate roots Fixed: Sub-clump shape change if Hair from Guides viewport percentage is changed Fixed: Corrupted string in macro recorder when editing clump amount value Fixed: Clumper crash if there are 0 input hairs Fixed: StrandAnimationModifier file path shouldn't be sticky Fixed: Using External Clump Guides method crashes Clump Modifier Fixed: GuidesFromShape on top of splines takes too long Fixed: Arnold dll is not installed correctly Fixed: Clump modifier "Add new index channel" option should not be sticky Fixed: Max UI freezes when continually resizing modify panel with ramp controls in it Fixed: Sub-clumping does not work for higher clump counts Fixed: Randomly generated strand roots can contain patterns Marsel Khadiyev (Software Developer, EPHERE Inc.) |
