I have a few lines with guides from shape modifier, when I apply hair from guides, nothing happens.
3dsmax 2017 + Ornatrix latest demo build
Any ideas what’s wrong?
You need to ground the guides to a mesh surface using Ox Ground Strands modifier
Thank you, I did that, but hair was generated outisde my view, that was the issue, now I used reset xform for both splines and base mesh so hair was generated in the right place.
Yes, it's important to setup the curves and distribution mesh correctly when using Ground Strands. Find more information on this video: https://www.youtube.com/watch?time_continue=1&v=w-Qhm7_Ff40
And in the documentation: https://ephere.com/plugins/autodesk/max/ornatrix/docs/6/Ground_Strands_Modifier.html
