Hello, I would like to know the workflow in which I have to deal with old projects that use the old ornatrix version. Is the only sure solution to install an older version of ornatrix? I have project in 5.X version and I can download only demo verion of that. In this case, Im not able to make any changes because it is a demo version. Opening 5.X version in 6.2.6 would cause lots of bugs or hair will behave in another way. Do you have any advice? |
| I added V5 access to for you so you can install older V5 builds. It'd be good, however, to hear about the bugs regarding opening V5 scenes in V6. Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| How can I send you file so you can open it in 5.2.9 and 6.2.6 to check whats going on? Both in 3dsmax 2018 |
| I uploaded it on wetransfer: https://we.tl/t-txpUS1GQIZ In 5.2.9 it behave correctly. Try to open it in V6 It was created in 3ds max 2018 |
| Did you investigated this issue? |
| Please describe in detail the issues you are having. I will take a look into them as soon as possible. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| Try to open this file https://we.tl/t-OgRB8bple4 in 3dsmax 2018 in ornatrix <span>5.2.9 then in 6.2.6</span> In <span>6.2.6 its behave not as it used to be in 5.2.9</span>
| I see the problem, we are going to look into it. As a workaround, open the groom in an Ox version where it works fine, collapse the guides below and including Edit Guides, resave the scene and open it with Ox V6. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| By collapse guides do you mean [Ox Baked Hair] and [Ox Edit Guides] on top? |
| It is BakedGuides. To collapse the guides you just have to selected the node that you have below HairFromGuides, right click and choose Select up to Here. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| Even if license is applied to my dekstop I got information that "No license for this product", while I'm using 5.2.9. |
| Hi Keid, To update the license amount please reinstall the license server. You can get it from your download page on the Install License Server Only section. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| Hi, Can you please re-upload the scene to WeTransfer? It expired before the team had the chance to download. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| https://we.tl/t-yzDf5l9AOV Created in 5.2.9 in 3ds max. Try to open in 6.2.6 |
