Hello Jeordanis.
Thank you very much for the response.
So i have figured it out because the process is quite self explanatory, however it does not work as intended.
Let me explain .
-The Frizz Amount is set to 0 (I do not want any general frizz)
-The ''Outlier Percentage'' is set to 0.2 (Meaning 20% of the hair will be Outliers, Right ?)
-The Outlier Channel is created.
Then i add 2x ''Change Width'' Modifier and set, one with no Channel for the overal Hair value 0.05 and one for the Outliers with value 0.02.
I then Assign the ''Outlier Frizz'' Channel to the second Modifier, but i CHANGES WIDTH OF ALL THE HAIR *
What i expect is for it to only affect the 0.2 (20%) that i set up before.
I hope i made the issue clear.
Is this a bug or am i doing something wrong ?
Thanks a lot .
