Purchase question?
Posted by:jfharper
Data created:26 July 2022
Do you have the previous full ornatrix versions available for download, like how you have the previous demo versions, for the different version of max?  I'm still on 3dsmax 2016 and would need to use ornatrix v6 for a certain workflow, then switch to ornatrix v7 for other workflows, due to the bugs in the software.  Thanks.
Yes, we can set that up upon request.
Thanks, I just purchased...do I request here or ?  I need versions:
Ornatrix_3dsmax_2016_6.3.6.25630
and
Ornatrix_3dsmax_2016_7.3.8.30738
available in my account for download please.  Thanks.
OK, I can download Ornatrix_3dsmax_2016_7.3.8.30738
but could you post <span>Ornatrix_3dsmax_2016_6.3.6.25630 to my account please...thanks.</span>
Done. You now can download V6 for Max.
Thank you.  If you can just get the Plant Roots and Sinks bugs fixed for max2016 v7, I would dialed in...why I need v6.
Steps to reproduce: max 2016 sp3
create sphere, add default furball, go to edit guides, try to plant roots...does not work for me, even moving roots is wonky.
add Surface comb above edit guides, go to sinks, then create button, try to draw a direction...doesn't work.
You guys have a nice piece of software there (besides the bugs).  Hope that helps, and you can fix it soon.
In this case, the bug is in 3dsMax 2016, namely in their ray-mesh intersection method. Later 3dsMax releases work.
It will take us time to work around that.
