Problem with hair roots
Posted by:jafar90
Data created:8 June 2023
Hello, the hair close to the surface does not get any effect for curling.
I tested all the modifiers that the problem was not from them, but I didn't find anything to solve it! I even thought it was a bug and started the hair-making process from the beginning, but again the same result appeared.
If you have an idea, I would be grateful if you could tell me to solve the problem
I forgot to add this, I tweaked all the curling modifier settings and the problem is still there, even the curling along strand option didn't help.
I guess there is something special about the polygon mesh that you are using to generate the hair. I can look into it if you can provide a minimal version of the scene for testing. You can either send us a download link using the contact page or DM me on Discord.
I received your email via email. I tested all the modifiers in the stack one by one and they are all affecting the hair as expected. See image below:
I tested on Max 2023 with Ornatrix 7.4.3.32514. If you are on an older build try updating and try again.
Thank you very much dear Jeordanis Figuereo for respond
