Hi Guys,
My max scene crashed as I was updating a distribution mask for new hairstyle. This map is used within the Guide generation tab on the 'Guides from Surface Modifier'. Any scene that used this texture in this way failed to open, then presented a PhysX error report, then a maxscript exception error and then max closes.
The only way to recover the files was to revert the distribution map, which I had luckily backedUp...Phew!
Once we use a distubtion map at this base level are we allowed to change it?
If we do, should it crash and lock out files in this way?
Any ideas what coud be going on?
Andy M
