Did not find any supported64-bit 3dsMax version!
Posted by:MSObruch
Data created:12 December 2018
Hello, tell me what to do with this error? I have installed 3dmax 2018, windows 64bit. During installation, this error occurs. Thanks you!
I have seen this problem before. This happens if you had Ornatrix installed for a certain version of Max, but then you uninstalled that version of Max and installed another without uninstalling Ornatrix. However, the problem can be something else. Please follow the instructions found HERE to help us debug the issue.
You are right, this is exactly the problem after reinstalling. How do i fix this?
You should uninstall your old Ornatrix first.
Do you have Ornatrix in Windows Apps & Features list?
If not, then it would be hard to uninstall it "the normal way". I'd suggest using some registry cleaner or uninstaller tool that can remove installed software.
If yes, it should be uninstalled from there. But given that it only supported older 3ds Max versions that you no longer have installed, it won't work unless we simulate that you have one.
To do that, follow these steps:
* Double-click the file SimulateMax2016.reg that I have attached here to import it into the registry
* Create the directory C:\Autodesk\3ds Max 2016\
* Uninstall Ornatrix from Apps & Features list in Windows settings. It should work now.
* Delete the HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\3dsMax\18.0 key from registry
* Delete the C:\Autodesk\3ds Max 2016\ directory
>SimulateMax2016.reg (135 bytes),
