Blend between grooms using MOOV?
Posted by:d3d
Data created:20 June 2019
Hey all,
Is there a way (without going to nHair) to blend between two grooms somehow?
Basically we have to do a wet/dry type shot and I am trying to keep this more straight forward and all in Ornatrix if we can.
That being said, unsure of the best workflow to do this. I know the attract to initial shape would probably be used for the sim, but without the concept of input curves (haven't seen anything in docs about it) not sure how to drive that transition.
I'm not sure I undertand. Do you want to blend between two grooms like a blend shape, with a control to animate a transition between the two grooms?
Sorry, I should have been more clear. Basically, we're looking for an art directable simulation. So if we could do something like what you're describing, then the attract to initial shape would drive the sim that way.
Though now I realize I basically want a way to art direct the initial shape?
But I think you get the end result we're going for, whichever way is best to achieve that. Hopefully within Ornatrix, if not that's ok.
