hair spawn object intersecting itself hair explodes
Posted by:kosta
Data created:8 July 2019
Can ornatrix handle an object which spawns hair, having the hair spawning object intersect itself, say a gorilla's arm that bends so much the forearm intersects the bicep.  The second mesh touches itself with remember root positions on, i get either hair explosions or the hair stays permanently pressed down in the areas that intersected.
Is difficult to understand the issue without the problematic scene. I don't know how you are setting up the hair stack, but normally this should not be a problem. Are you using simulation?
