| Posted by: | fernandospirit | |
| Data created: | 15 October 2020 | |
Hi, 1) After I place a GUIDE(strand) single, how do I move entirely the guide for a different position IF I placed wrong?
2) Is there a way to delete all guides at once? Or I have to remove using the remove brush?
Seems that the brush creation or grab does not work always with mirror on. | |
| 15 October 2020
#29000 | |
Hi, 1. Select the strand and move it using Maya's default move tool. 2. There is a button in Edit Guides to remove all selected strands. I cannot reproduce the mirror issue with the Crate and Grab brush. Can you try to reproduce this in a new scene with a sphere? You may also want to try with the latest nightly build. Jeordanis Figuereo (Product Designer. EPHERE Inc.) | |
| 16 October 2020
#29001 | |
Thanks Jeordanis. I will try the latest build too :) | |
| 23 October 2020
#29058 | |
Hi Jeordanis, I feel that the new ornatrix v3. Have a few features that are missing. 1) A brush that moves only guides. 2) A brush for select/unselect guides. The hotkey is missing for unselect single guides.(we can just select, but not unselect). You guys could setup - SHIFT + LMB -> to select 3) The add Guides Brush, depending on how you press. Can come 1-X guides.(Even with Root count =1). And seems that the new guide does not conform properly with other guides around.(Should have switch ON and off to conform with guides around) Very hard to work without being able to move guides around freely. During the process of grooming, it crashes quite often with V3. thanks
| 23 October 2020
#29063 | |
This is a Maya bug. Find the solution here. As you can see it is working correctly here:
Use Maya's default transformation tools. See the link above for more details.
Press Shift while in brushing mode to activate the selection brush.
For now when in Edit Strands Mode you can select and unselect guides as any other Maya object, with the same hotkeys. We will look into adding more hotkeys to the selection brush.
<span>I don't quite understand the first issue. Can you please record a short video showing the problem? </span> <span>As for the second issues, the Create brush seems to conform the new guides properly. If this issue is exclusive to a particular scene then we need it for testing and debugging. </span> <span><img src="https://i.gyazo.com/7ee1ec92c45ff812bb19ff2576aadff2.gif" alt="" width="720" height="774" /></span> <span><img src="https://gyazo.com/7ee1ec92c45ff812bb19ff2576aadff2" alt="" /></span>
If you experience any crashes try to reproduce it and do the same in a new scene. If it can be reproduced in a new scene please share the steps here. If the crash can only be reproduced in a particular scene we need to look into it. Send us a simplified version of your scene for debugging. Jeordanis Figuereo (Product Designer. EPHERE Inc.) | |
| 28 October 2020
#29076 | |
Hi Jeordanis, | |
