How to create braids through clumps?
Posted by:buss47
Data created:13 January 2021
I am missing a step? i created just a simple clump and then added the braid guides in the cluump patterns section and nothing happened. how do i create braids?
Nevermind, i understand now.
allthough one question does cross my mind, which is how to make the clumped hair not go through with the mesh i have push away from surface active but if i go to higher value it moves to far away.
It will depend on how you have setup your guides. If the hair is going inside the mesh I will have to take a look to understand the problem. In most cases the cases are:
  • Not enough guides.
  • You are not using a distribution map.
  • Not using parting and it's needed.
