Hi there,       So, I'm trying out Ornatrix for Maya again   And it seems to me I have some weird sink selecting issue going on.   I have sinks added to my mesh and whenever i click "edit" sinks in order to correct the direction of the sink, it will select some totally random sink and will "edit" this one instead.   Bug or some workflow error? I noticed that you have changed surface comb node in the later version.   I have the latest Ornatrix Demo version downloaded and installed.       Thanks for any help.  |
 | Hi,   Do you mean that when you try to select a sink, it selects a random one?  Jeordanis Figuereo (Product Designer. EPHERE Inc.)  |
 | Yea   when i click on a specific sink, it activates a random one instead and i am not able to edit the originally selected sink.       i could try to record a video while i am back at my computer, in case my explanation of my problem here is a bit vague.  |
 | Is it working fine for you know? I was able to reproduce an issue that could cause issues when selecting sinks, but is not exactly like the proble you had. We are looking into it.  Jeordanis Figuereo (Product Designer. EPHERE Inc.)  |
 | Hi,   problem stil remains with maya 2018. If i create just two sinks, then it will select correct one. when i am creating more than two it goen nuts.   and it is pretty laggy.   however, tried with maya 2020 and it seems to act OK.
    cheers  |
 | i am having this problem still in Maya 2020 ive atached a video. Sometimes it works, sometimes it doesnt, and it seems to change when i move my perpsective position. sometimes I can "realign" the selection so it works but only from a very specific angle, its very strange.       I also get the following error on selection:   Error: file: C:/Program Files/Autodesk/Maya2020/scripts/others/toolPropertyWindow1.mel line 72: Object 'OxSinkManipulatorContext' not found  |
 | Hi Guys,   I still can't reproduce this. I tried in Maya 2017, 2018 and 2019. However, I did found another issue that could be related. We are investigating, I will keep you posted.  Jeordanis Figuereo (Product Designer. EPHERE Inc.)  |
 | I am having the same issue with Maya 2020. Also the base point of a selected sink is oddly moving when I try to edit is direction or length by selecting the point.      |
 | Mike,   Can you try again with the latest nightly build? Also make sure that you are not in base Maya 2020, at least 2020.1 is requiered.          Jeordanis Figuereo (Product Designer. EPHERE Inc.)  |
