Hi, if I create a braid and load it as a clump pattern it seems to work fine- however I do the same thing with hair generated from mesh strips- maya crashes, should this be possible ?
thanks
Andrew
Hi Andrew,
This is a bug, I can reproduce the crash. We will look into it and get back to you. Thank you.
Thanks Jeordanis!
I cannot reproduce this again in the latest nightly build. Can you try it please?
Hi, it's no longer crashing! Thank you!!
Have in mind that the hair from mesh strips needs to be grounded to a surface using Ground Strands node to be able to use Clump Patterns.
