Hair from Mesh Strips - Issue with Strand Groups
Posted by:crisjsalina
Data created:31 March 2021
I'm not able to create Strand Channels using Hair from Mesh strips. I don't know if the issue is on my end or not, but here's what I try to do:
-I create the hair using "Hair from Mesh Strips"
-I create "Edit Guides"
-I choose "Edit Strand Mode" from the Edit guides attributes.
-I select the Paint Brush and try to paint but nothing happens. The value is not assigned.
-Even if I try to set the value of my seleccion using the "Assign Value" button under the "Channels" tab, nothing works.
Can you please help me? Thanks.
I can reproduce it. We are looking into this issue. I will keep you posted. THank you.
In the case of Hair from Mesh Strips you have to set Change Tracking in  Edit Guides > Interpolation Options to Strands instead of Surface.
Thank you. It worked!
