RenderMan 24
Posted by:Bennell
Data created:31 July 2021
Is Ornatrix for Maya 3 compatible with RenderMan 24?
At the moment I don't have a way to try RenderMan 24. The non-commercial version doesn't seem to be compatible with Maya 2022, and the plugin doesn't load on Maya 2019.
I can confirm that Ornatrix is compatible with RenderMan 23 thought. I suppose you have RM24 working in your Maya version. Can you try it yourself with the demo version of Ornatrix?
I cant get it to render.  It will only render mesh from strands.  It also will not render more than 50,000.
Yeah same issues as BilgeRat, Maya 2019 RM24.1. Any idea when this might get fixed?
We are finally able to test this and the team is already working into this. I will keep you posted. Thank you for reporting this issue.
Confirmed, our hair procedural doesn't work with PRMan 24.
Can't tell when it will be upgraded, PRMan 24 seems to have changed a lot, we'll most likely need some help from Pixar about it.
Does the hair procedural work with PRMan 24 yet?
No, there are problems, and there's no help from Pixar.
