Sinks not saving with scene Maya 2022 Ornatrix 3.2.6
Posted by:FreddyO
Data created:24 August 2021
Hello.
Sinks are not saving with the scene, when reloading the scene the groom appears to be there but no sinks to edit. Is there anything in aprticular I need to do to save the sinks. if I save the Groom, will the sinks save with it?
Hi Fred,
Are you able to reproduce this on a new scene with a sphere and a fur ball? If so, please share it here and we will look into it asap.
trying to re create it on a sphere it won't do it, that being the case, it leads me to believe that there was something wrong with the particular scene I'm working with. I went back to my scene and optimized it, and deleted the history, and now it it is working. Now I can seve the groom, and it loads with sunks in other scenes I have animation in.
I'm not sure what was causing it, there's probably a rogue node somewhere.
if I can recreate it on a clean scene I'll be sure to send it your way. and thank you for the quick reply and willingness to help.
If you have an older version of the scene that still have this problem we can take a look into it.
