Remove VrayOxHair node
Posted by:philippfarmer
Data created:6 February 2022
I used the "Add V-Ray Hair" funktion just to test it, but it didn't work at all. It just got stuck in "compiling geometry" forever. Not really a problem because I was okay with my renders before and just wanted to test it. So I simply removed the node again. But now my hair isn't rendering at all. What is the right way to remove that node? Or what else do I need to do to render with Chaos' primitves again?
Thanks in advance
Found the solution. After you deleted the node you have to go into the "Extra Attributes" of the shape node and under "Render Info" you have to tag "Layer Renderable". Maybe you could add that info to the Docs for other dumbos like myself :P
