Linux network issues
Posted by:it.accounts@pukekopictures.com
Data created:16 March 2022
I'm trying to get Ornatrix installed on a network share and then loaded via a launcher script for ease of updating and maintenance.
The idea is that when installing a new build, I can run the .run file, move the extracted files into a folder with the version number, then update a variable in the launcher and we are good to go.
However when loading maya I'm getting the following error:
Plug-in, "Ornatrix" was not found on MAYA_PLUG_IN_PATH
The launcher script is here below, and as far as I can tell from the readme included in the installer, I've specified all the paths. Is there anything I've missed or could try?
#!/bin/bash
export QT_COMPRESS_TABLET_EVENTS=1
echo "Launching Maya 2022v3"
echo ". . . . . . . . . . . . . . " | pv -qL 12
# Setup the Redshift license variable
export redshift_LICENSE=XXXX@XXX.XXX.XXX.XXX
#Set up Ornatrix
ORNATRIX_VERSION="3.3.5"
export EPHERE_MONO_DIR="/puk/apps/Ornatrix/$ORNATRIX_VERSION/Apps/Ephere/Mono64"
export ORNATRIX_GROOMS_DIR="/puk/apps/Ornatrix/$ORNATRIX_VERSION/Data/Ephere/OrnatrixMaya2022/Grooms"
export ORNATRIX_PRESET_DIR="/puk/apps/Ornatrix/$ORNATRIX_VERSION/Data/Ephere/OrnatrixMaya2022/CurvePresets"
export ORNATRIX_SCRIPTS_DIR="/puk/apps/Ornatrix/$ORNATRIX_VERSION/Data/Ephere/OrnatrixMaya2022/Scripts"
export MAYA_MODULE_PATH="$MAYA_MODULE_PATH:/puk/apps/Ornatrix/$ORNATRIX_VERSION/Module/"
exec /puk/apps/autodesk/maya-2022v3/bin/maya ${@}
Sorry for the late reply, I missed this post.
I'm not a LInux user but I will ask someone else to take a look.
The script looks correct to me, I'm trying to spot some defect, but can't.
I assume the .run file was extracted into the /puk/apps/Ornatrix/3.3.5 directory
You may verify that MAYA_MODULE_PATH is correct in Maya, use "getenv MAYA_MODULE_PATH" in Script Editor, check that /puk/apps/Ornatrix/3.3.5/Module is indeed included.
Also check in Script Editor the value of MAYA_PLUG_IN_PATH, it should contain /puk/apps/Ornatrix/3.3.5/Module/OrnatrixMaya2022/plug-ins
Hi Ivan,
Thanks for that. I eventually found why it wasn't seeing the module path and got it to load.
Now on the next problem, the crashing. I'll start a seperate thread for that.
Thanks!
