Edit Clumps - Unable to select
Posted by:stasismedia
Data created:4 July 2022
As my title suggests, I am unable to select individual clump guides. I use clump editing tool but it instantly shows all clump guides are selected, I cant deselect them or select individual ones. If i click delete clumps then all clumps are removed.
I am using maya 2022 and have tried all version of Ornatrix from 3.3.0.29155
I dont understand why it wouldn't work as I remember before I could select individual generated clump guides and remove them if they were interferring.
OK, so could someone else test this...start up maya with display preferences as Direct x11 and apply a clump modifier, try editing the clumps/select seperate clump guides (turn yellow)....this doesnt work for me.
Now change display preferences to openGL - Core Profile, now do the same as before, apply clump try to select.....this works...at least for me it does. Is this a bug?
Cheers!
Sorry for the delay. We do not support DirectX 11. You need to use OpenGL to work with all the GPU display and color overlay features in Ornatrix.
