| Posted by: | plboily | |
| Data created: | 31 January 2023 | |
Hi, Im having a crash when im adding a "groundStrand operator" if im not rendering my scene before creating this operator. First i was trying this by script, so my Finallayout team will be able to create by script the scene, but i found that issue whil i was creating by script the workflow. So i tried to simplified the problem and it seems its the same issue in the UI. This is where i get the crash: 1) Import your Ornatrix Alembic hair 2) Import AddStrandOperator 3) Render 4) Crash
1) Import your Ornatrix Alembic hair 2) Render 2) Import AddStrandOperator 3) Render 4) NO CRASH
Any idea what can i do to refresh the ornatrix hair by script and not starting a render before operator creation process? Can you repro the problem on your side? Linux Rocky 8.5 maya 2022.3 ornatrix 3.3.9 (same problem on 3.4.0)
Thank you Pierre-Luc B.
Thank you Pierre-Luc B. |
