Strand Group does not work
Posted by:seanE1
Data created:21 August 2023
I am following this documentation (https://ephere.com/plugins/autodesk/maya/ornatrix/docs/1/Edit_Guides_Operator.html#Strand-Groups)
and I cannot get the Strand Groups to work.  First i check on "Use Strand Groups" and "Display Strand Groups", then select the "Edit Strands Mode" brush and when I select the guides, it seems like it wont let me select anything. The guides does not change the color after try selecting the guides.
Does anyone have this issue? I use Maya 2020 with Ornatrix v4.1.3.32690 in Window 10
Thanks!
Do you mean that you are unable to select guides to assign strand groups to them?
If you have vanilla Maya 2020, check the minimum requirements. It mentions that Update 1 is needed for Ornatrix to work properly on Maya 2020.
Also notice that you are looking at the documentation for Ornatrix V1. The docs for V4 are here.
Thanks for the help.  I am using Maya 2020.4
I tried resetting Maya preference and everything works now.
Thank you!!
