Problems of flickering guides
Posted by:FrancisBlueDot
Data created:10 November 2023
hello,
I'm making fur on realistic animals, that are animated.
Problem is that guides along the UV seams keep flickering and I can't seem to work this out.
If I go at the very bottom of "guides form mesh" and change the unused attributes from "texture coordinate" to "1st edge", I don't get this problem anymore but then my hair does not grow evenly and doesn't seem to take the texture information on some parts. Creates like a checkerboard texture on the character, some fur showing white and some black in the viewport. In render, some fur appears darker and some lighter, following the same random chackerboard pattern.
Any help would be appareciated ...
We are aware of this issue. We don't have a solution yet but the team is currently looking into it.
I will let you know if I can come up with a workaround.
ok :'(
For anyone having the same issue, my workaround so far : animating a few keyframes, see what guides are flickering and deleting them manually. Sometimes it creates a big patch of nothing but with a bit of luck hair interpolation will cover it.
