After installing the ornatrix plug-in in maya2025 of the apple m3 system, a fatal error occurs when opening maya again.
Posted by:1253861261@qq.com
Data created:27 October 2024
After installing ornatrix on the Apple m3 computer maya 2025, a fatal error occurred after opening it with Rosetta, causing maya to close.
Please provide more info.
I just tested our M2 Pro with Ventura, Maya 2025 and latest Ornatrix build, it's working.
Make sure you're really running Maya in Rosetta mode (check the 'Kind' column in Activity Monitor for the 'Maya' process, should be 'Intel')
Try running Maya from Terminal, to see more info about the error:
/usr/bin/arch -arch x86_64 /Applications/Autodesk/maya2025/Maya.app/Contents/MacOS/Maya
This is what I got after running the command you provided
>m3_maya2025_crash.log (21900 bytes),
Please help me solve the installation problem, thank you
Right, I confirmed this with the latest stable build, 4.2.4.
Please use the previous stable build 4.2.3 until we release a new fixed build.
ok,thanks!
