Ornatrix for Maya is not rendering in Maxwell
It should be working fine. Which build of Maxwell are you using?
maxwell 3.1.1.1.0
everything else shose up except the har
I think your Maxwell is outdated. I use 3.2.11 here and all works as expected. Do you have access to newer builds of Maxwell?
Ah much better thanks.....it had said there were no updates so I went to the site.
Can you put a Maxwell shader on the hair or is it even neccessary?
I think you can do either one, Maxwell or standard shader
