| Posted by: | asamiya83 | |
| Data created: | 11 September 2016 | |
Hello, I'm trying to render some hair simulation done with nHair. So I have the cached curves in ABC format. These are the steps I've done so far. - Import character scalp (alembic cache) and the simulation curves. - Create Ornatrix hair from curves. - Add the scalp geometry as distribution mesh and ground strands. - I use UV or Random distribution. But the hair don't follow the original alembic simulation. I also tried not to use the distribution mesh and select guides as hair in the distribution type. This makes the hair follow perfectly the cached simulation, but theres no hair distribution of course... so it only renders the viewport number of hairs. I hope someone can help me with this issue. I'll keep trying, though. | |
| 11 September 2016
#10388 | |
Thank you for the description, we will investigate. Marsel Khadiyev (Software Developer, EPHERE Inc.) | |
| 12 September 2016
#10389 | |
Hi asamiya83, can you please attach a scene here that reproduces this issue?
| 12 September 2016
#10392 | |
Thank you for your reply. Here is a maya scene with the ornatrix setup, a scalp for the hair distribution. And a cached simulation in ABC format. As you can see, there is an offset between the alembic curves and the hair. Thank you again! Attached Files: | |
| 13 September 2016
#10393 | |
Thanks for the scene. It seems that the main problem is that your base mesh (RightSide) does not follow the hair splines. The guides are following the splines (that's why "guides as hairs" renders the hair at the position of splines) but the hairs stay planted on the mesh since guides (and curves) transforms are not actually animated, only the vertices are. | |
| 15 September 2016
#10394 | |
Thank you for looking at the scene. You are right! I tried different ways, but when I added a wrap deformer to the scalp from the character rig, the curves follow the movement correctly. Thanks again. | |
| 21 October 2016
#10735 | |
Hi, I encounter a new problem with the alembic workflow, maybe some one else have seen this. I imported the simulated cached curves into Maya, then apply a groom preset to the curves. Everything looks good but, the groom is intermolating the hairs between the curves, and these curves are moving so Ornatrix is interpolating the hairs constantly, creating new hairs in some frames, so the hair pops and changes. Is there a way to make the hair interpolation static and keep it the same through the whole animation? Hope someone can help. Thanks! | |
| 28 February 2017
#12469 | |
Hey asamiya83,
I use the same workflow, applying the groom to a set of curves that are simmed using maya hairsystem. Here are my steps. Steps
Export/ import
After sim is complete
Import for Lighting
You rinterpolation issue is probably due to the remember button in the HairFromGuides node. You need to check this off or the groom will recalc the root position every frame.
-James
| 28 February 2017
#12470 | |
You can also use the anim cache workflow but as of now, I am not able to get this to work with HairFromGuides. Still plugging away. | |
