Scalp area
Posted by:vieirafel
Data created:16 December 2016
Hi !
Hi I'm beginner user ornatrix in maya, I usually have used ornatrix in 3D max.
in 3D max when you select a mesh to be your " scalp" area this area turn invisible, than you can put with differents meshes over your main base mesh but it's invisible, just the guides apears, but in maya it's no work this way (I guess so), the question is, how the best way to work with more than one hair group in a mesh ? example : mustache and hair and beard with differents presets.
thanks you for your time
Hi Felipe,
You can hide the Distribution Mesh by uncheking the "Visibility" option in Atributte Editor - Object Display. Is that what you are looking for?
If you want more than one hair system/Groups using just one distribution mesh you can use Distribution Maps to isolate the areas where you want the hair. Let me know if that works for you.
Best Regards,
Jeordanis Figuereo.
that's axactly what I needed!! thank you!!!  the first one was what I looking for! thank you jeordanis!!
Best Regards
Felipe Luiz
