Ornatrix hair not rendering with arnold
Posted by:zatoid
Data created:28 January 2017
Hey guys, I'm trying to put together a proof of concept for our professor to purchase a license for our pipeline this semester but I'm having issues rendering the hair with arnold, I downloaded just the trial version so I'm not sure if that has anything to do with it, if anyone can offer a solution to fixing this that would be awesome.
This is what I'm getting when I hit the IPR button
http://imgur.com/YXEmnEX
Hi Zatoid,
I just tried here and I was able to render correctly. Arnold has been through some big internal changes last year, if you are using an old version of Arnold you will not be able to render Ornatrix hair, I suggest you update Arnold to the latest version available and try again.
Hi Jeordanis, thank you for the quick reply, I'm currently running it in Maya 2017, the version of MtoA is 1.3.1 which is what is listed as the version that should be most compatible with Ornatrix hair, though I'm not sure if that is the latest release of MtoA.
I'm using Arnold 1.4.1.2. The problem is, Solid Angle made some API changes and we had to change Ornatrix internally to work correctly with new versions of Arnold, that's why new versions of Ornatrix won't render on new versions of Arnold. In resume, you need to update Arnold :)
Ohhh ok, I'll give that a go, thank you again!
