// Error: Ornatrix: Private\TriangleMeshAccess.cpp(772): Assert failed (5):
Posted by:Thor@pixelmolkerei.ch
Data created:11 February 2017
Hi I get always following error when setting the mapchannel count to 2 for feathers
Maya 2016 SP1
// Error: Ornatrix: Private\TriangleMeshAccess.cpp(772): Assert failed (5): fnMesh.assignUVs( textureChannelAfterEditing.uvCounts, textureChannelAfterEditing.uvIds, &textureChannelAfterEditing.name ): (kInvalidParameter): No element at given index
Which version of Ornatrix are you using?
Hi i Think i have a workaround
I delete the MeshFromStrandsNode which is originally created and made a new one...
Interessting fact is that i have a similar issue with the slope ramps... the originally created are hardly editable but if i make a new one they look as they are suposed....
best regards
Thorsten
Hi i just downloaded the latest build 1.1.8.10082 [Latest Stable]
Hi Thorsten,
I can confirm this issue you mentioned about the slope ramps, we will look into it, thank you for the report!
