When grounding hairStrands, is it possible to know which polygons the strands are grounded or connected to? Is so, how?
Hi Franken,
Each guide is grounded to the closer polygon face. Is that what you mean?
No, I'm trying to also have the Maya polygons selected that the grounded hair are attached to.
You can create guides grounded to a polygon selection by selecting the polygons and using the Add Hair button, but you canot use GroundStrand node this way, with GroundStrand you can select objects only, not components.
