Saving a guides from curves hair stack
Posted by:teddude75
Data created:18 November 2017
I'm trying to save a hair stack that is generated by an alembic curve. It's basically a hair system on a character that the bangs and side burns are simulated with nhair and it's exported out as an alembic. Than I make the hair stack from those curves. I don't won't to build the hair stack for every scene. Is there a way to save the hair stack and switch out the curves while keeping the the modifers above it?
TED
Hi Ted,
Do you mean the groom preset? There is a button to save the groom preset at the bottom of the stack.
I wanted to make a hair stack from alembic curves
with the ability to switch out the curves without affecting the look of the hair. I found a solution with changing the file path in the maya acsi file.
