V2 Beta (2.1.2.15335 [Nightly]) does not support V-Ray?
The following error appears.
V-Ray : There was a fatal error updating the scene at time 1.000000 for V-Ray
Tested on V-Ray 3.52.03 / 3.60.04 maya
This happens because the new ChangeWidth operator is not compatible with VRay yet. To avoid this error use the RenderSettings operator instead, use the following MEL command to add it to the operator stack:
OxAddStrandOperator "" "RenderSettingsNode";
Thank you. solvedPlease add RenderSettingsNode to the Ornatrix menu.Like 3dsMax's VRayOrnatrixMod modifier.
