Two questions with Moov Physics
Can I simulate and caching Moov Physics with Maya Batch?
If simulation is possible with Maya Batch, is a license required?
Best wishes, ------- Yuji Yamauchi OakCorp Support |
| Hi Yuji, Simulation currently can only be performed through Maya GUI or with a script (MEL or Python). I will see if we can support batch evaluation. Could you please provide some more detail on your desired workflow? Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Simply execute the simulation from the command line and caching. End users will be pleased if a license is not required for command line simulation. But you have that judgment.
Thanks for consideration
| So, to understand this correctly you'd like to use maya batch to: - Load a scene
- Select the dynamics node
- Run simulation and record it to an .abc file
If so, this is already possible and license is not needed Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| It is the procedure that our customers want.
Simply do it with pre-render MEL? Could you tell me the example MEL?
I'm sorry for the trouble. |
| Please see here: https://ephere.com/plugins/autodesk/maya/ornatrix/docs/2/Simulate_Hair_with_Maya_Batch.html Marsel Khadiyev (Software Developer, EPHERE Inc.) |
| Thank you for details! That will be helpful.
