In plugin manager, vrayoxhairmaya is not loaded. What should I do?
I see an error occurs when trying to load this plugin. We will look into this and get back to you as soon as we can. Thank you for the report.
Same here. Did you find a solution?
We are still working to update the vrayoxhairmaya to work with the new VRay 4 SDK. I will update this post when this task is done.
