Hey, Yeah I have tried all combinations. When I up the fur count I actually notice it in all areas.
I think it is a problem with the interpolation between guides.
Is there a way to force the interpolation beyond 3? I wonder if the basic count of guides is just too low. Pic attached
You can see in the pic, more terracing on the sides.
-one side note -- Does the smoothing of hair curves relate to tesselation of the underlying mesh at all? I am render-time smoothing currently, but could do one level of poly smooth if it helps.
Temporarily, I will try to convert the length (the most drastically affected value) to a texture map, which is tedious!
