Is there a way to hide guides for more workflow clarity ?
Posted by:FlowS
Data created:12 February 2021
Is there a way to hide guides during styling process ?
Indeed, guide often disturb the visibility and it's difficult to figure out what does looks like the final hair style like in this exemple :
Guides disturbing visibility
If we hide visibilité with C4D object buton, It just disable the hairs.
What I would like, is to let them enable but not visible.
I can't find this info in documentation.
Inside Edit Guides>Guide Operations, there is an option to hide selected guides. In Guide Options, there is a checkbox to hide all the guides.
Thanks, I was pretty to use this option in the past but couldn't remember how to achieve it.
Maybe a more accessible checkbox will be convenient for this kind of repetitive operation.
This is a guide operation, so I think it makes sense to have it in Edit Guides. Soon the UI will be revised anyway, we will have this in mind. Thank you.
I see "hide guides"...but I don't see any "hide selected guides".
The Hide command in Edit Guides will hide the selected guides:
I don't see that. This is what I see.
Ok, it's in root mode. You didn't mention that. When should I be in root mode versus strand mode?
Something seems wrong with this procedure. If I select some guides to be hidden, then unhide them -- they stay red selected and can't be unselected. Also, the hide button greys out.
Also, when hitting the hide button, some hairs get selected on the other side of the groom and won't get unselected. It seems buggy because there's no way anyone could be produective with the way it is now.
Is up to you. Each mode allows you to select and edit guides in a different way. More information about edit modes can be found here.
I cannot reproduce that here. When unhide guides there are not selected. The Hide button is greyed out when no guides are selected. I tested on R23, latest Ox stable build, Windows:
Same for this one. It works the same as in the gif above. No extra guides selected after using the Hide button.
Please double check here that you have a compatible version of C4D. Also, what OS are you using?
Am i using the correct version of Ornatrix?
2.1.9.27645
It depends more on your version of Cinema 4D. I'am asking because you are having bugs that I'm not able to reproduce. I want to discard compatibility issues.
