I'm using mesh strips grounded to a scalp object. I can render the hair by itself and the character by itself, but never together. When one is visible, the other cannot be. |
| Hi, Please send me this scene for testing. I will check what is going on there. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| To make the scene smaller, I deleted everything except the head and removed a lot of the data like posemorphs, etc. The problem is still there so there should be enough to use to check the issue. Just check ON Ornatrix at the top of the list and the character will vanish. I was mistaken....it isn't just the character. Everything disappears. Lights, geometry, etc. If I make a new parametric object, that will stay visible. It's very possible it's related to my character object, because I've had some scene weirdness when deleting polygons. But in this case, Ornatrix causes the problem. |
| Thank you, I will take a look. I noticed that you don't have any distribution mesh set in Ground Strands > Distribution Mesh. So this modifier is not doing anything actually:
| As a workaround, disable Hide Mesh Strips in Hairs from Mesh Strips > Mesh Strips tab. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| That fixed the viewport visibility, but the character still won't render with Ornatrix on. I'm starting to think that the problem may be my geometry. It was imported from Softimage from a very old project and the polygons have behaved weirdly since I've been working on it. If I delete any geometry from it or make modifications, everything turns into a mess on screen. I'm going to start over with a new character. |
| Jeordanis, the problem was R24. I went back to R23 (and the scene was backwards compatible) and the problem doesn't exist anymore. Actually, there's a lot of problems overall in Cinema 4d that don't exist anymore when going back to R23. |
| This particular bug was fixed for the next nightly build (28464+) which will be online soon. What other problem is solved by just going back to R23? Btw, check the compatible C4D builds here. Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
| There were some overall problems with the c4d gui (you can find a post about it on the Redshift forums). Panels and icons would disappear and also sometimes the viewport would freeze and not be viewable. r23 doesn't have those issues. r24 definitely does, so I stopped using it. |
| Any other issue related to Ornatrix in R24? Jeordanis Figuereo (Product Designer. EPHERE Inc.) |
