Ornatrix-C4D-0-0-4-17783-win64.7z file used same error as above. By the way, thank you for your hard work, appreciated very much. kind regards. M |
| Should be fixed in the next nightly. Ivan Kolev (Software Developer, EPHERE Inc.) Discord: ikolev Email: ivan.kolev at ephere com |
| Hello Ivan Thanks. Does it have something new if marked Old? |
| Changes to hair interpolation are currently under development in the shared code. But any needed changes to the UI will come to C4D later. Ivan Kolev (Software Developer, EPHERE Inc.) Discord: ikolev Email: ivan.kolev at ephere com |
| Hello Ivan, thank you Wow! New 0-0-4-17862 brings new operators!!!
Curves from strands and hair material are not working. Attached Files: |
| Hi, thank you for your support, Since Ver 0-0-4-17862 till now Ver 0-0-4-17882 Still hair matrrial are not working, when you click on create feather C4D crashes, still testing.... Mina |
| Hi Mina You're right. But i hacked it by MoSpline  I'm thinking that it's messing with new caching system Attached Files: |
| Hi iLay7k Thanks for the tip, and many thanks for all your support. Mina |
| The nightly builds were rather unstable lately because we started making some drastic changes. Most importantly, we're switching from tags to deformers. We'll upload a new "stable" version soon, though it's expected to be much less stable than the previous one. Ivan Kolev (Software Developer, EPHERE Inc.) Discord: ikolev Email: ivan.kolev at ephere com |
| Hello Ivan Thank you and team! |
| Hello Dev.team Last nightly builds have strange thing from hidden CONSTRAINT TAG with turn off of PSR - so we have incorrect position i make custom script assignment of hair with switch on PSR Attached Files: |
